WHAT IS THE WEIGHT OF 67 AND 68'S
I can not find information on what my 67 and 68's weigh.
Will
Will
67 F-250 CUSTOM, 428, 4 SPEED, DISC BRAKES, P/S, EATON ELOCKER, 3.54 GEARS
68 F-250 CAMPER SPECIAL 360, C-6
- woods
Re: WHAT IS THE WEIGHT OF 67 AND 68'S
2wd, 250, with gas, oil, water and you sitting in it...probably a little shy of 5000 lbs.
- woods
Those numbers make me wonder...When you guys with an F250 4X4 go over the scale at the dump, what does it read? With the bed empty (aside from an aluminum toolbox), my orange 71 is almost exactly one ton heavier than the advertised curb weight.FORDification wrote:http://www.fordification.com/tech/dimensions.htm
I run about 250 lbs, the tool box is probably 200, the winch and front bumper is 200, figure 120 pounds of fuel 10 pounds of oil and 30 of water.
That should put my truck at 5,070 lbs. I have some lighter engine parts, so knock off around 70 lbs there. My tires are bigger and heavier, so it "should" come in around 5,100 if we base it at advertised curb weight. It's more like 6200. It's up or down 20 lbs from this from scale to scale. So do I have a mystery 1000 pounds on mine or do you guys come in around the same weight as me?
'70 sport custom long box. 302/3 spd manual column shift. No accessories. 265/75-15 tires on steel wheels. 4140 lbs. I make regular dump runs and the scales always read the same.
- woods
So you're about a 1000 pounds over your dry weight correct?
Where are the advertised vehicle weight ratings? I guess I will run the scales also.
Will
Will
- cowbay
I find that amazing how light these trucks were compared to today's. My f100 is lighter than my 63 Chevy impala. So this lead to my next question what would the tow ratings be for these bumps of different sizes
- BobbyFord
I weighed my short bed before I put the 460 in it.
360, C6, A/C, P/S, P/B, full tank of gas, me in the cab = 4,100 lbs.
- woods
Great, even my truck is fat.
- fomocoguy
My crew comes in under 5700 with me in it, so it's about 5500 or a little less.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
The chart says a 67 F250 2X2 styleside weighs in at 3815 lbs. Hmm...mine weighed 5250 last time I parked on the scales empty. Take me out of the cab and that would be 5000 lbs. I carry some ballast in the bed but not that much...wonder what my 16-inch steel belted radials weigh? Lots more than stock tires, but...??
Keep in mind that for that '67 chart, they're basing the weight on a standard truck with standard equipment. Therefore, the trucks would've been weighed with a 240 and a manual 3-speed, and wouldn't have included P/S, P/B, A/C, radio, exterior trim, hubcaps, etc, and would have bias-ply tires. And since the trucks were typically delivered without a rear bumper or a spare tire, those probably weren't included as well. That stuff adds up pretty quickly.
- cowbay
FORDification wrote:Keep in mind that for that '67 chart, they're basing the weight on a standard truck with standard equipment. Therefore, the trucks would've been weighed with a 240 and a manual 3-speed, and wouldn't have included P/S, P/B, A/C, radio, exterior trim, hubcaps, etc, and would have bias-ply tires. And since the trucks were typically delivered without a rear bumper or a spare tire, those probably weren't included as well. That stuff adds up pretty quickly.
Good point. All makes sense
- thrush544
Woods, ... you just crack me upGreat, even my truck is fat.
"Courage is being scared to death, but saddling up anyway." - John Wayne
Proverbs 3: 5-6
Proverbs 3: 5-6
