2wd highboy???
360F100
2wd highboy???
Post by 360F100 »
Looked at a 69 F250 today. It sat kindda tall and it was 2wd. So i asked him who put the leveling kit on the front. He told me that it as a F250 Highboy. I thought, uummmm a 2wd Highboy?? Did they make a 2wd Highboy? I was under the inpression that all Highboys where 4x4 and the frame was different making them sit taller than most trucks. Hence the name Highboy.
1972 F100 SportCustom
2wd 360/C6/9"
FORDification
Site & Forum Admin
Site & Forum Admin
Re: 2wd highboy???
Post by FORDification »
No, there's no such thing as a 2WD Highboy. Granted, it's a slang term, but it's used only to describe a '67 thru '77-1/2 F250 4x4 with a divorced transfer case.
360F100
Re: 2wd highboy???
Post by 360F100 »
I wonder why its sits so high then? I know the frame does look a little different than my 72 F100. Is this because its a F250?
2wd 360/C6/9"
FORDification
Site & Forum Admin
Site & Forum Admin
Re: 2wd highboy???
The F250 frames use a slightly thicker metal, but not so much that you could really see it with the naked eye...you'd have to mic it to tell the difference. Otherwise, you couldn't tell the difference between an F100 and F250 frame if they were sitting next to each other.
I'm guessing it was simply a matter of the springs not sagging and maybe slightly taller tires.
Madman
Re: 2wd highboy???
Post by Madman »
Totally agree, what made them highboys was the clearance required for the transfer case. The guy probably just jacked it up in the front to make it level or appear more aggressive.
2017 Ford Raptor
1975 Ford Bronco
