Suggestions for tire brands?
- Green Steel Ranger
Looking to replace the 235/85-16's on my 71' F250.
1971 F-250 2wd Ranger, Camper Special 360, C6 AUTO, 3.73 Dana 60
- 1972hiboy
Re: Suggestions for tire brands?
Depends what you use the truck mostly for. More highway use and good life span I would recomend the Dunlop radial rover a/t's good all around tire with a long life span. But if you see the dirt/snow more often you may want to consider a more agressive tread design. Do much towing?
Rich
Dont eat yellow snow.....
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
For a good economical, and quality tire made right here in the good old USA take a look at Cooper Tires, just pick the tread design to match your style of driving.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
Thanks. Not too much dirt and mud in my future. I have heard good things about Cooper though. I'll look into those Dunlops too.
- mrtleavitt
I got the Cooper CTS about a year and a half ago. Very good tires. They are a street tire and I was pretty hesitant to switch from the good old BFGs that I've ran since I could drive (10 years now). The coopers are holding up very well with all of the 428 burnouts!
1969 F100 428 with T19, 3.00 9inch 31 spline w/ Detroit Trutrac, '74 frame swap successful!
http://s43.photobucket.com/albums/e356/mrtleavitt/
Decided to go with a set of Cooper Discovery H/T's in a235/85-16
Very happy with the ride and wet weather performance.
- 1970 Hi-Boy
Glad to see you went with a made in America choice, I'm sure there is a worker out there that appreciates it as well.
