HELP!!Pickup makes my clothes smell like Oil/Gas
- 71Ford
My wife complains everyday when I get home because my clothes smell like oil/gas from driving my pickup......She's not amused when I tell her,"It masks the scent of perfumes the stippers were wearing ; ) ." ANYWAY is anybody else having this problem??? Is it a carburetor problem or exhaust problem. My pickup does not smoke at all. I've had my carb rebuilt, replaced fuel pump, timing chain, etc., etc. but the exhaust is 35 years old w/ 200K so I might need to change it out..but like I said, it does NOT smoke at all.
Thanks for any suggestions,
Shawn
Shawn
http://www.fordification.com/galleries/ ... p?pos=-851
71 XLT RANGER ->203,000+MILES/NOT REBUILT
99 GMC 4x4 Suburban, 94 Saturn 200k, 03 Chev Venture
- heep70
The exhaust is probably leaking fumes.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 72hiboy4x4
- 71-F-250SC-72-F-250C
re: HELP!!Pickup makes my clothes smell like Oil/Gas
It may be running rich? I like the smell of the oil and gas. Thats how my truck smells.
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic. ![Smile :)](./images/smilies/icon_smile.gif)
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
72 f-250 Custom
03 mach1 mustang
- rjewkes
I That that is how all ford trucks 20-30 + years old are supposed to smell!
Try changing the rubber parts of the fuel system.
Filler neck to tank. Any and all crossover(early Smog Crap before the pump.) Hoses and the gasket around the sending unit and the gromet around the fill neck. were it goes through the body.
- 71Ford
Thank you everybody for the reply...I'll try those areas next.
Shawn
Shawn
- flyboy2610
If you have the in cab tank I would start by replacing the filler neck hose. Those get old and crack, leting gas fumes into the cab. Do NOT use radiator hose for this!
You can get the hose from LMC or Dennis Carpenter, or you may be able to get one from your local auto parts store.
You should always look for the simple solution first.
Drive nude....
Drive nude....
- flyboy2610
No, the nuns in the station wagon find that terribly distracting.
- cavedweller
My wife is starting to think something is going on.................
smell like gas and oil and hands don't want to come clean even with gojo.
Actually she is really cool about the whole thing, but mine smells to. I think I need to work on the carb some more.............or get that straw I've been sipping on out of the cab tank
No wonder gas is so D@mn high.
![Surprised :o](./images/smilies/icon_surprised.gif)
![Sad :(](./images/smilies/icon_sad.gif)
![Woohoo! :woohoo:](./images/smilies/icon_woohoo.gif)
- rjewkes
in response to gas it is the lowest it has been in the last 12 months or so. Atleast in Joplin, Mo. 2.03 87
2.08 89 2.20-2.28 90-92 octane. and 2.75-3.19 for deisel.
- 71Ford
Thanks ya'll....I'm glad I'm not the only one that has this problem.
Shawn:D
Shawn:D
- Sharkdance
I agree with 72hiboy4x4 and flyboy2610, The back of the seat could be saturated with fuel/fumes or the tank filler hose could be broken. But here is one other thought.
If your 71 has the vapor canister venting system check those lines as well. You will know it by simply folding the seat foreward and looking at the top of the tank for what looks like a copper pipe loop with a few hoses running off to the passenger side of the cab.
There is a vapor canister mounted under the hood on the frame that could be clogged/mucked up causing a venting issue inside your cab.
It may smell like gas inside your truck and you may not notice it because your used to it.
- OR -
Have you lifted the carpet recently? Are the floor boards still solid?
Could be exhaust fumes seaping up thru the bottom of the cab. Check all firewall plugs and seals where wiring, heater/AC system passes thru as well.
In short. If it smells like fuel or exhaust in your cab fix it A.S.A.P! That is a dangerous situation that shouldnt be taken lightly.
- OR -
