This is stupid
- jzjames
This is stupid
Id like to know if you are supposed to lubricate lug nuts/bolts. Ive hurt myself a few times loosening rusted lugnuts, and Im getting too old for that. I dont want to hear "absolutely not" and "yes, absolutely". C'mon.
Can I figure this out before I die?
- michael69
Re: This is stupid
No, but You can use anti seize
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Re: This is stupid
I use anti seize every time. Had a bad time with not doing it to my Dart after i installed my willwoods an new weld drag light wheels, ended up costing me almost $800 later to fix the damage. Now i use it on every vehicle, i also check once a month for tourqe on all my lugs its a habbit now
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
Re: This is stupid
Also to each his own on what they have found works the best for them. I found out what works for me an im sticking to it.
-Mike-
ECV 1849
ECV 1849
- basketcase0302
Re: This is stupid
I've always put just a few drops of motor oil onto the lug nut's first two or three threads. And clean up the threads first with a brass wire wheel prior to that if need be.
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Re: This is stupid
I've used Anti-seize on mine for a long time, sure does help. Even if I end up being silver up to my elbows every time I use it. What is it with that stuff anyway? Seems the harder I try to keep it off of myself, the more of it I get on me.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
- Kurt Combs
Re: This is stupid
I agree with those above, clean up the threads on the studs and use anti seize. Torque to the proper specifications, not too tight. Should not be a problem in the future.
Kurt
1972 F-250
1972 F-250
- 1972hiboy
Re: This is stupid
whoa! ok you can use wd-40 or a light oil but anti-seize in every old shop ive worked at has made sure to explicity explain that this was a no-no. It makes it easier to overtorque and damage the threads. Not to mention reduce friction so those nuts can back off easier.....no one else had heard that? maybe its a cali thing.....
Rich
Dont eat yellow snow.....
- robroy
Re: This is stupid
JzJames, thanks for asking this. I actually didn't know this mattered; I've always used regular black grease on those threads.
- jzjames
Re: This is stupid
Thanks for your opinions, I actually googled this before I posted here to ask you guys. I got "a dab of grease just on the first 3 threads", anti-seize, oil, WD40, and none of it would cause the lug bolts to back out as a rule.
Like I said, Ive strained some tendons and things when I was young. Makes me cringe. The last time I tried some of my motorcyle chain lube in the spraycan, but sometimes the stuff just seems to dry out by the next time I have to take a wheel off.
I thought there might be one correct way to do it.
- 1972hiboy
Re: This is stupid
jzjames wrote:Thanks for your opinions, I actually googled this before I posted here to ask you guys. I got "a dab of grease just on the first 3 threads", anti-seize, oil, WD40, and none of it would cause the lug bolts to back out as a rule.
everything in moderation right???lol
Rich
Re: This is stupid
Having recently twisted off 3 water pump bolts and had to bust a timing chain cover due to one of them being fused to it, I will ALWAYS use anti-seize now and in the future.
- eggman918
Re: This is stupid
In the shops I worked at that did repair for the oil patch and heavy industry anti-seize was the norm on damn near everything
threads, registers, metal to metal surfaces and in many cases gaskets. Aluminum based in most applications copper based for
temps over *1,000f
Steve.
temps over *1,000f
Steve.
- Mancar1
Re: This is stupid
Used anti seize in the engineering spaces during my 24 years in the Navy and use it to this day. It works and the nuts will not back off due to its use. Of course this is just my
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- colnago
Re: This is stupid
I put nothing on, and torque to the proper spec. Not using a torque wrench ruined a pair of rotors once. Never a problem with the proper torque.
Joseph
Joseph
