trans linkage
danno
trans linkage
Post by danno »
I put a c-4 transmission in my truck and took a steering column & linkage out of a 74 f-100 which had a c-6 trans,will that linkage work for the c-4 trans or do I need to find a different linkage rod.As of right now the shifter does not line up with the the marks on the column (like D R N 21) even if I adjust it on the rod to the trans....
65 f-100 4wd short bed 360engine c-6 tranny
Whateverman
Re: trans linkage
Post by Whateverman »
the shift arm on the trans is probably the wrong length,i had to extend mine by about an inch i think. The correct length for the shift arm is given in the pic here:(3 1/4" centre to centre)
http://www.fordification.com/forum/view ... a&start=15
If doing things the "right' way is your mode of operations you can take the valvebody out and change the shift arm -- too much mess and bother for me, i just made a bolt on arm extension,one of these days i'll shoot some pics of it
danno
Re: trans linkage
Post by danno »
Thanks man that's what I was wanting to know,
