Just about have everything
Mancar1
Post by Mancar1 »
I Have the Sanderson headers, Edelbrock aluminum intake, Aluminum valve covers, and Edelbrock air cleaner. Now when the Holly carb shows up and the 2.5" dual exhaust and all else is installed the 68 Camper Special 390 will wake up a little :thup: :D :drive:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
jimmy828
Re: Just about have everything
Post by jimmy828 »
Just like Christmas. How you going to act with all those toys? :hd:
Mancar1
Post by Mancar1 »
jimmy828 wrote:Just like Christmas. How you going to act with all those toys? :hd:
Like a :D 64 yr old kid going VAROOM down the hwy :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
sargentrs
Post by sargentrs »
Can't wait to hear how she does with all the new stuff :thup:
HIO Silver
Post by HIO Silver »
The parts list sounds is really familiar...Can I add to your list?
- Since ya gotta pull the rocker arms and push rods, consider installing a 70 carb jet under the rocker stand's oiling passage to direct more oil to the mains. A pair is abuot $5.
- A 3/4-inch heater hose fitting for aftermarket manifolds... NPD PN 18599-10 ($10). It 's a 90° fitting which omits the extra port for the carb spacer.
- Thermostat
Btw, I suggest removing the 3/8-inch pipe plugs and flushing the block before installing the headers. One on each side. It requires a 3/8-inch socket unless it has petcocks.. I undid mine and nothing came out until a poked it with a small screwdriver and then torrents of grit, slime, and scale came out. You'll be amazed at how much coolant remains in the block even after it is apparently empty. It's the only right way to do it.
Mancar1
Post by Mancar1 »
HIO Silver wrote:The parts list sounds is really familiar...Can I add to your list?
- Thermostat
Thanks for the suggestions. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Mancar1
Post by Mancar1 »
Ordered that fitting and was told I will have it within 2 days. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
HIO Silver
Mancar1 wrote:Ordered that fitting and was told I will have it within 2 days. :thup:
:thup: Attaboy.
'got mine today... here's a pic for reference for the rest of the guys:
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
timmytim
Post by timmytim »
:thup:
:fr:
buy'em dirty sale'em clean
get more money for the same
machine.....
:loco:
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
