Top Speed of a 68' F100
Subzero
Post by Subzero »
This is probably a well known thing around here, what kind of top speed can I achieve with a 68' F100 with a 360, auto trans, and 3.25 gear ratio? Not that I plan on speeding around in it or going racing but just for general knowledge :lol: . I've never taken mine over 70 for fear of over-reving the engine. There is a red line starting at 70 mph mark but no tach in these trucks so I figured that line meant red-line for the rpms.
Thanks
sargentrs
Re: Top Speed of a 68' F100
Post by sargentrs »
Don't know about a 360 but I've had my 302 with 3 spd and 3.25's over 90 on the highway several times.
460 crew
Post by 460 crew »
Had my 4x4 crewcab 460/c6 4.10 gears on 35's at 130mph a few times. That's how u beat the new junk on the road by running faster than their speed limiter! Yes eventually a torque converter incinerated in there, but easy fix.
My dads 69 2wd with 390/np435 and 4.10's hung in there till a little over 105 I think.
Subzero
Post by Subzero »
I'm glad to hear that the truck can exceed 70 as that is the speed limit on some interstates around me. What does the red line mean that starts at 70 mph mark till the max 100 mph mark then?
Mancar1
Post by Mancar1 »
Then the max speed limit 70. Then when when it was 55 some vehicles had red at 55 and over. The red is just a warning/reminder to slow it down. Or ticket time :lol: Now back to 70 :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
thejunkman
Post by thejunkman »
Yeah I've had a few cars with the 55 in red to "remind" you of the speed limit. :D My truck doesn't have a tach and the speedo doesn't work, but I can feel when she's running out of steam. A lot of it depends on what rear end ratio you have and what not, as far as highway speeds and rpms are related.
-Dave
1967 f100 long bed 2wd, 390, np435
1999 Mercury Grand Marquis
Mancar1
Post by Mancar1 »
I have the 4:10 Dana and I cruise at a comfortable 70. I am going to go to a higher gearing.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
elgemcdlf
Post by elgemcdlf »
The top speed of a bump is not based on the truck. It is based on how big your balls are!
rltvader
Post by rltvader »
Ill admit, I have taken my truck to the redline. I have a hot 302 and a c4 tranny and my speedo stopped at 100, but according to my friend his read 100 and I kept moving away, guesstimated at 105-110.
-Built Ford Tough for a Reason
1969 F100 Red/White LWB (302)
1972 F250 Camper Special Ranger White LWB (FE)
Damon23
Post by Damon23 »
Had mine up to 65 and it was not struggling. I've yet to stretch it legs but don't really want to.
JG F100
Post by JG F100 »
460 crew wrote:Had my 4x4 crewcab 460/c6 4.10 gears on 35's at 130mph a few times.
wow!!!
I've been up in the 90s easily with my overdrive but as I dont have any sound deadening it feels like I'm in a Nascar truck, feels great!
460 crew
Post by 460 crew »
wow!!!
Lol yeah it was spinning like a top and had to make sure I had plenty of real estate ahead of me. Was running a garmin GPS for a speedo. Had a 3in dual in single out flow master 70 series dumping b4 rear wheel and l&l headers, wasn't too bad cab is coated with hippo liner, firewall cover and thick insulated carpet.
Best cruising speed was between 65-75.
motzingg
Post by motzingg »
35 inch tires at 130... now that takes some balls. My ranger on 30's got pretty loose around 80 and started pogo-ing in the back.
