aftermarket steel replacement parts
doughboy68
Post by doughboy68 »
just got my new aftermarket core support and I have a question...are they ready to install or do I need to primer and paint prior to install??? I am leaving black so????? :fr:
elgemcdlf
Re: aftermarket steel replacement parts
Post by elgemcdlf »
Paint it. That is just a coating to keep it from rusting while in stock. I don't remember what it is called.
jimmy828
Post by jimmy828 »
I had ask the same question when i purchased mine. From the advice from some on this site ,i decided to scuff,prime,scuff again, then paint. I used spray bombs. After all the work it took to change it out i was looking for a little more protection.
chad67
Post by chad67 »
The black is an electrostatic coating to prevent rust while on the shelf, but offers very little chemical or UV resistance. If left unfinished, it will turn chalky and the part will eventually start to rust through the coating. When I put on a new body part, I always paint the inside before I put it on, too. Leaving the inside with only the electrostatic coating is why a part with a good coat of paint on the outside will rust from the inside until the outside bubbles and cracks off like an egg shell.
1967 F100 SWB
1991 Thunderbird 5.0 with fully ported gt40 heads, cobra intake (also ported) and a trickflow stage 2 cam, manual steering, and custom 3" exhaust
doughboy68
I thought it was something temp... I will get r done!! Thx for the input!!
HIO Silver
Post by HIO Silver »
elgemcdlf wrote:Paint it. That is just a coating to keep it from rusting while in stock. I don't remember what it is called.
I think it means Electro-Deposition Primer.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
