1967 Only List
Calvin Gunter
1967 Only List
Post by Calvin Gunter »
I've got a good friend who recently bought a 1967 Bump and I was trying to tell him all of the 67 only things and I need you guys help. Here's what I have so far.
Ignition switch
Hood (underside bracing, top the same)
Radio
Doors(arm rest, door panels, door opening handle)
Grille
Inside mirror
Heater Controls
Hood emblems
Vent window handles
Ash tray
Emergency brake pedal assembly
That's all I have for now, Please add on, Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
67dually
Re: 1967 Only List
Post by 67dually »
352.
Calfdemon
Re: 1967 Only List
Post by Calfdemon »
Most of the differences are listed right here: http://www.fordification.com/tech/67-72ID_01.htm
-Rich
Current toys -
Former toys -
HIO Silver
Re: 1967 Only List
Post by HIO Silver »
I got this from a highly regarded source over on FTE:
'The hood is basically the same 1967/72 F100/750. The original 1967 hood (C7TZ-16612-A) had slightly different cross bracing, and that's it.
Ford replaced C7TZ-16138-A with the 1968 hood C8TZ-16138-A. Then in 1970, replaced C8TZ-16612-A with D0TZ-16612-A = thus: 1967/72 F100/750. If you're a purist, you'd want to retain the original 1967 hood.
1967: You push the inside handles forward to lock the doors from the inside. 1968/72's have door lock knobs.
1967 only: Door shells, window regulators, door lock remote controls, door latches and link rods, inside window and door handles, vent frames & handles, armrests.
Firewall, dash panel, radio & heater, instrument cluster back, brake & clutch pedals, bracket they suspend from. Master cylinders, P/B boosters, proportioning valves, low brake fluid warning lamp switch.
Hood side emblems, painted steel and anodized aluminum grilles. Ignition switch: C5AZ-11572-B sameas: 1965/67 Galaxie/LTD/Thunderbird / 1966/67 Fairlane/Falcon / 1967 Mustang/Cougar.
Same 1967/72 door parts: R/L upper/lower hinges, outside door handles, door lock cylinders, door and glass weatherstripping, window & vent glass, division bars.
C3UZ-18495-A .. Heater Water Valve-Splices into inlet to heater core heater hose: 1965/72 F100/1100, 1963/67 E100.
1967, 1968 before serial number C56,001: The upper side mouldings are 1 1/4" wide // 1968 from serial number C56,001, 1969, 1970/72 Sport Custom: The upper side mouldings are 1 1/2" wide.
There are two different inside mirrors. 1967 beforeserial number A70,001: C5ZZ-17700-C .. Chrome (same as 1965/66 Mustang).
1967 from serial number A70,001, 1968/69: C7OZ-17700-C .. Day/Night-Black vinyl, paint to match (same 1967 Fairlane/Falcon).
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
mk
Re: 1967 Only List
Post by mk »
F100 frt brake drums
washer fluid bag
pre dec 66 built early production 67s used one flasher box for both signal and emerg, also early hood hinges were slightly different
dash knobs
brake/clutch pedal support bracket
glove box push button
white paint on steel instr cluster bezel
and probably other things... :D
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
fireguywtc
Re: 1967 Only List
Post by fireguywtc »
No factory AC was available in 67, dealer only. No disc brakes were offered on the 67 models, disc became available for 250/350 in 68.
Bill
jzjames
Re: 1967 Only List
Post by jzjames »
You guys got it covered pretty good! I cant think of anything I could add.
There used to be a '67 Ford Truck registry, that is no longer current. I dont know what happened to it;
https://groups.yahoo.com/neo/groups/67F ... s/messages
I wish it was still around.
Calvin Gunter
Re: 1967 Only List
Thanks Guys, The list keeps growing. I thought of two more to add, brake pedal for automatics, and the brake light switch. Thanks again and keep them coming.
