The Right Stuff
ToughOldFord
The Right Stuff
Post by ToughOldFord »
Okay, I’m not skimpy at least when it comes to buying tools. I have tools around here that may see use once every five years or so. I have some that I have forgotten that I even own that show up every once in a while. However, I’ve never bothered to get a simple little gasket scraper. Ever since I could turn a wrench I’ve been using screwdrivers, putty knives, utility knives, and razor blade scrapers. Yesterday I was using the latter to clean the valve cover gaskets off the 390 I’m building for my ’69 and after the umpteenth time of the blade shoving itself back into the scraper I gave in to frustration. Today I bought an actual gasket scraper. Difference is night and day. Should have bought one years ago.
You got to have the right stuff, even with small items.
:woohoo:
1970F250
re: The Right Stuff
Post by 1970F250 »
yeah i've always used screw drivers and stuff too. :dk: lol
mrung0wa
re: The Right Stuff
Post by mrung0wa »
Brother!
:2cents: There is no match for a red, green or brown 3M pad attached to an angle die grinder for scraping gaskets! :wink:
Lawrence 8)
capeclassics
re: The Right Stuff
Post by capeclassics »
I loved that movie!
1970F250
Post by 1970F250 »
i just replaced my vc gaskets yesterday. what a pain. i almost lost my thumb! :eek:
mrung0wa
re: The Right Stuff
Post by mrung0wa »
There still is no match for a red, green or brown 3M pad attached to an angle die grinder for scraping gaskets!
If you have an air compressor with at least a 20+ Gallon tank(the larger the better!).
Buy yourself an angle die grinder and get those Scotch-lok pads and 3" and or 2" applicator.
It'll be one of the best investments you'll ever make...
Lawrence Image
Big D's 69
Post by Big D's 69 »
I finally purchased a gasket scraper when I put the cam in my 00 SS Camaro. Up till then I had just used what ever was handy. I really like the air method with the disc. So much easier but not real good for aluminum if your not careful.
