what is this light for ?
thin41
Post by thin41 »
One more general question and thank you ahead.
What is the light socket (no bulb yet) for on the far left lower corner on the surface of my dashboard for on my '69 F250 ?
About as far left and down as you can go near the driver's door - looks factory installed, but when I've looked at other dash pictures that bulb/ socket
is not there ? Left and down of headlight switch.
Thanks.
'69 F250 KCMO
SevNT2Bump
Re: what is this light for ?
Post by SevNT2Bump »
That's your brake warning light. I didn't know what it was for either, until it actually came on.
Ken
72' F250 Custom 2wd 360 C6 auto
99' GMC 1 ton dually flatbed 454
07' Ford Ranger 2wd 4.0 Sport
thin41
Post by thin41 »
hummm - thanks - I'll have to find a bulb and see if it works - ha.
for the emergency brake on ? is that what it is for ?
'69 F250 KCMO
SevNT2Bump
It means you have a problem with your brakes when it comes on.
Ken
Ranchero50
Post by Ranchero50 »
Ditto, it means your proportioning valve has shifted enough for the switch to make. Mines been on since I put it back together. Bleeding the brakes didn't shift the pin back to center so some day I need to pull it out and manually reset it. Mine is down on the drivers frame rail, a real PITA to get to.
SevNT2Bump
Mines on also. It came on after I redid my brakes.
Ken
fastEdsel
Post by fastEdsel »
Yes it is a brake alarm light. When I overhauled the brakes on my '68 F100 the light came on. A mechanic told me to press hard on the brake pedal and hold it for a few seconds, you should feel the brake pedal give a little pop and the light should go off. I did that and it worked. It worked for me but yours may be different.
fastEdsel
Post by fastEdsel »
I should also add and am assuming this has already been figured out that the truck must be at a full stop or parked before you press hard on the brake pedal. I would hate to hear that when the brake alarm light was re-set in this manner that your entire ammunition supply, groceries and beer cans went flying into the defroster vents and from under the seat. :doh: Keep the rubber side down! :thup:
Copper67440
Post by Copper67440 »
I'm not at home with my 68 right now but was wondering the same thing. What # bulb does it take. I want to pick one up while I'm out and check it when I get home.
Henry helped pay for it all.
Copper67440
#1895. Just like the rest of the dash bulbs. Which I replaced with all LEDs. My whole cluster is nice and bright.
