I was decoding my new 70' camper spec. and the axle code it says 38. I don't see 38 under 70' in the vin sect. But there is under 69' Dana 60 3.73. Is this just a mistake or what? I know it has a dana 60 but trying to figure what gears it has. Thanks.
Charlie
rear axle code
- 72hiboy4x4
if all else fails, crawl under the truck and look for the tag hanging off one of the bolts holding the cover on.
- HOWDY69
The Chilton manual says 38 is a 3.73 starting in 75. I don’t know why I am telling you this since I have very little faith in their tables.
re: rear axle code
Thanks, I'm going to climb under there this weekend and look for a tag. I'm guessing it's a 3.73. When I drove it home it did'nt really scream for another gear coming down the road unlike my 66' with a 4.10. I just wonder why the tag has a code they did'nt use in 70'. I know it's the original door with factory rivets.
Charlie
Charlie
- 4x4x4crewcab
re: rear axle code
My Ford Master Parts Catalog (May 71) shows code 38 for 70/ up trucks as being------Single speed,3.73 (5.2 M),Dana 60
Hope this helps.
Hope this helps.
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
1999 Ford Windstar
re: rear axle code
The '70 VIN page has been updated to show this. Thanks Mark!
