famous last words...
- wndsofchng06
Bought another one!
Got a 69 f100 6cyl 3spd. My first inline 6 Ford truck...any tip s, tricks, hints?
Runs great, gotta replace the rag joint. Plan to make this my DD!
- HIO Silver
Re: famous last words...
Yep.. I said to myself that I was out of parking spots then a stray 71 F250 followed me home ....
- wndsofchng06
Nice!
- wndsofchng06
Got her back from the shop today.... Rag joint made a huge difference! Now I need to focus on the fact that the bearing/bushing in the steering column for the shift linkage is falling out the bottom if the column...anyone dealt with this before?
- wndsofchng06
so for the first time in years I pay someone to fix a vehicle... and the new rag joint broke as I was driving it away from the mechanic shop today then to top it off the 3 speed on the column does not shift between 1st and 2nd either direction. So you have to get out of the truck and do it manually under the hood. Any suggestions?
- wndsofchng06
- ___TRASH___
thats the shifter i have in my '67 f100 installed by the previous owner, took some getting used to but it's ok......my wife can't shift it though
i have a top loader that i'm gonna swap in as soon as i get some time.
and i like the truck,whats your plans for it ?
Shop Labor rate................$85.00/HR
if you watch.................... $95.00/HR
if you help...................... $105.00/HR
if you worked on it first...$120.00/HR
- ___TRASH___
sorry, i was looking at HIO's truck ....got any pics of yours ?
- wndsofchng06
I do have pics.will have to post them tonight. Right now just get it functioning, it's my daily driver!
It sounds like you steering column needs a rebuild, but make sure the cab mounts are good before you try to fix anything else. This is the cause of a lot of shift/rag joint problems. With all of this solid you can then adjust the linkage.wndsofchng06 wrote:so for the first time in years I pay someone to fix a vehicle... and the new rag joint broke as I was driving it away from the mechanic shop today then to top it off the 3 speed on the column does not shift between 1st and 2nd either direction. So you have to get out of the truck and do it manually under the hood. Any suggestions?
HIO Silver wrote:Yep.. I said to myself that I was out of parking spots then a stray 71 F250 followed me home ....
[ Image ]
I love that orange... What color is the inside?
JB
- wndsofchng06
Here's a pic. She's ROUGH!
- HIO Silver
The OP had it repainted Calypso Coral.. the interior is the original color, Regis Red. It's not as brilliant but really close... the ol' girl need a bit of cleaning. There are smudges and slightly greasy fingerprints from the OP. Maybe this weekend I'll get to it...jlb wrote:
JB
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- wndsofchng06
Holy crap! $400 to rebuild the column!!!! She's driving now
- HIO Silver
Time is money.... your time is 'free'.wndsofchng06 wrote:Holy crap! $400 to rebuild the column!!!! She's driving now
