Another power steering pump / steering box failure question
ximy
Post by ximy »
I have a Saginaw box and Eaton pump. My pump failed (no sound or pressure) and the steering just stopped, no power at all. :(
I replaced it with a rebuilt pump and the rebuilt pump would not pressurize the box at all. :eek:
I figured it was a bad pump so I took it back for another. :thup:
The second rebuilt pump ran for about 1/2 hour before it failed and there was no power to the box again at all. :doh:
The box was resealed (because of leaks) about a year ago and ran fine up till this fiasco, so I know the fluid has been pretty clean. :thup:
So, before I replace the pump again is there any way the steering box is causing the pumps to fail? :wf:
Thank you
1967 f250 428
ximy
Re: Another power steering pump / steering box failure question
Post by ximy »
nobody has any ideas huh?
I'm going to remove it again this weekend. First I guess I'll try to rig up some hoses to see if there is pressure from the pump If there is, I'll check the return line pressure from the box.
1967 f250 428
BobbyFord
Post by BobbyFord »
You may likely have a sticking control valve inside the steering gear.
I doubt that more than one pump went bad.
ximy
Post by ximy »
BobbyFord wrote:You may likely have a sticking control valve inside the steering gear.
yeah, it's not looking good for the box.
1967 f250 428
Kurt Combs
Post by Kurt Combs »
I highly recommend a Red Head replacement. Spendy yes, but better than Napa or O'Reilly's parts. The Red Head will have new bearings in the bottom of the box where the shaft goes through, the other rebuilt boxes don't bother they just change the seals from what I experienced.
Kurt
1972 F-250
ximy
Post by ximy »
Kurt Combs wrote:I highly recommend a Red Head replacement. Spendy yes, but better than Napa or O'Reilly's parts. The Red Head will have new bearings in the bottom of the box where the shaft goes through, the other rebuilt boxes don't bother they just change the seals from what I experienced.
Thanks, I bookmarked redhead.
On Saturday I started it up and the steering was working. This leads me to believe the headers are overheating the steering box.
This steering, lock-up symptom, never happened before I installed the headers.
I noticed the headers tubes, all four run parallel (see red lines) with the sector shaft housing for about 12 inches.
Could the headers be causing the box to seize??
I made a head shield and I'm going to look for a cooler and maybe add a filter too.
any thoughts?
Here is the heat shield
1967 f250 428
ximy
Post by ximy »
Heat shield installed. Seems to help, the box hasn't seized yet with it in.
I just attached it to that existing bracket at the top.
It is totally shielding the box from the header tubes.
1967 f250 428
AZf100
Post by AZf100 »
So Was this The Problem Heat? Or?
ximy
Post by ximy »
Yes, I believe it was the heat seizing the box. It has not seized since I made the shield and I have not had to put on a cooler. So far so good. :thup:
1967 f250 428
AZf100
Post by AZf100 »
Good Deal, sounds like you got it figured out. :thup:
