1969 F100 4X4 steering column
mdart
Post by mdart »
I have a 69 F100 4X4 with 4 spd manual trans. Just recently bought this truck. The steering column had a lot of play and the lower bearing is too small for the column. The bearing measures 1.187
The bottom of the column has a 1.335 diameter where the bearing would press in but I'm not sure if a sleeve is missing or what.
I took the column out of the truck figuring I'd replace what ever is broken or missing.
Could someone tell me what parts I need and where I might be able to get them. thanks
Re: 1969 F100 4X4 steering column
Lmc part number 46-0741
