Dont be a previous owner
One guy took an axe and chopped a circle in each kick panel so he could install speakers. That got wet and ruined from being put in the cowl drain area. Lol. What a previous owner this guy was.
Anotjer guy cut off the turn signal switch wiring. He drove around like that i guess. No signals no brake lights. Another previous owner rig.
Anotjer guy also took an axe an put a hole in the low hump for a shifter to go thru. Then stuffed foam aroynd the shards of piece of the axed up hump. Then used expanding foam to hold it all together. This was one of the worse rigups ive ever seen.
Another gut took part of a wiring harness from a non gauge truck and used it with his guage main wiring harness. He had all kinds if electrical problems.
Dont be a previous owner. Be responsible
Do it right.
jg09
Re: Dont be a previous owner
Post by jg09 »
Our Ranger still has a hole in the hood left by a hatchet :?
1966 F250
2017 F150
Mancar1
Post by Mancar1 »
Someone come buy the 68 and I will B previous. They can B responsible. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
sargentrs
Post by sargentrs »
Any time I've ever sold a vehicle, I've always done my best to tell the new owner exactly what I've done to it and why. At least they can't say they weren't warned. :D
shortstack
Post by shortstack »
If you're going to install an aftermarket radio, just bend the mounting tabs out of the way. No need to cut them off. Three bumps in my "parts department" have some serious hack jobs from lazy previous owners.
1971 f100 Custom, SWB, 302, T5
"It can't be that hard."
AZf100
Post by AZf100 »
I Have a 78 With a hasp and a padlock on the hood, Previous owner told me the hood kept flying up on him. :dk:
radioactivelarry
Post by radioactivelarry »
Solved some electrical gremlins the other day. The PO installed a Kenwood stereo after hacking the dash but the worst part was the rear of the radio was jammed into and resting on the wiring connector for the wipers creating a short. Loose grounds behind the cluster and live wires left over from previously installed goodies like a CB radio and that old kind of vintage stuff from back then. Some wires were jammed under a fuse in the fuse box also. Wow, fixed that and no more shorts! Most things now work except for the steering column wiring for turn signals etc. I changed and shortened the column after adding power steering. I did that the right way, no Mickey Mouse, with mostly genuine FoMoCo parts.
So, after solving all the previous PO's nightmares and getting it all straightened out does this mean my truck will be fresh and if I sell it this PO will have done it right for the new owner so there won't be any PO issues? :hmm:
Does that make any sense?
Democracy is two Wolves and a Lamb voting on what to have for lunch. Liberty is a well armed Lamb.
Ben Franklin.
My Motto: I wish I had less to do, more time to do it in and got paid more for not getting it done.
:drive:
6Delta
Post by 6Delta »
radioactivelarry wrote: So, after solving all the previous PO's nightmares and getting it all straightened out does this mean my truck will be fresh and if I sell it this PO will have done it right for the new owner so there won't be any PO issues? :hmm:
Yes it makes sense. But no. You will always be a PO who gets blamed for everything you did not find and fix. My advice is NEVER sell.
Unless you do a complete frame off, rotisserie restoration and replace/rebuild absolutely all components. There will be something you may miss. Therefore keep your bump and just upgrade things that break (or you want to). Face it, bumps rule but they can always be improved if done properly and within your skill set. (Why is it most PO's could not manage to make any electrical change without screwing up more than what they were working on?" I just discovered that alligator clips must have been the inspiration for most of the work done by my PO. Not just additional trailer wiring but a set of driving lights, long gone, as well. Just strip, connect and add lots of black tape. Lots and lots of black tape. Just in case someone wanted to do it right, might as well make it hard I suppose. Once again do not sell, EVER. Buy another if you have to but do not sell. (Of course that is why I may need an intervention regarding Rancheros.)
This could be a new category actually. "What screwed up thing(s) did the PO do?"
No Brain - No Pain
71 F250 Sport Custom Camper Special
71 Ranchero Squire
70 Ranchero GT (Red w/351C 4V
70 Ranchero GT (Black w/302+)
03 Kawasaki Vulcan 750
74 Kawasaki H2 750 (Widowmaker)
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
urchinhead
Post by urchinhead »
The electrical problems of every old vehicle I have owned have been the direct result of an aftermarket stereo install - including my F100. Why, why, why!!!???
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
duaneo
Post by duaneo »
The funny thing is, installing an aftermarket stereo in these trucks isn't THAT hard. 4 wires + speakers.
Then again, I have friends I wouldn't trust to plug in a lamp into the wall properly. :)
Cheers,
Duane
1971 F100 - Ugly on the outside, but purty under the hood...
1968 Chevrolet Impala - Family car since 1970, My car since I was 16, in need of bodywork/paint, but otherwise straight.
2004 Mini Cooper S - Daily driver and grown up go-kart
1 Crummyshooter
Post by 1 Crummyshooter »
Don't ever buy from an electrician. We can get really creative when it comes to wiring.
Due to the high cost of ammunition, you can no longer expect a warning shot.
When someone was beating on my door hollering "Alcohol, Tobacco, and Firearms", I naturally assumed it was a delivery.
Dave Severson
Post by Dave Severson »
Funny stuff here guys!!! Some of the stuff you find and maintenance methods used on the old stuff is hilarious!!! Got to laugh about it when you find what some PO did on your own future pride and joy or you'll wind up mad enough at the PO to hunt him down and adjust his thought process with a Louisville Slugger!!!
I was very fortunate when I bought my bump, I got it from the 2nd owner who was a retired farmer. The truck had received excellent care throughout it's lifetime. The first owner, also a farmer is a very fussy type of guy who maintains everything he owns to a very high level! Over the years on other projects I've seen some really scary stuff, though! I've got one of them Brand X cars that a young Hot Rodder had here locally, must have had some issues with the front brakes so his solution was to remove the calipers and cap the brake lines!!!! :( I believe the young fella was going to try to drag race the car as a lot of the extra weight was removed including the heater and air conditioning system---he then covered the whole in the firewall with a piece of 1/8" masonite---which he had painted rattle can flat black to match the rest of the decor under the hood!!!
Maybe somebody needs to record these and all the other PO stories and write a book about "How NOT to restore a Bump".... Sure would be full of funny stories and not-so-good fixes!!!!
Retired and lovin' it!!!!!
elgemcdlf
Post by elgemcdlf »
Never underestimate the human animal when it comes to ingenuity. It scares me knowing these jewels are out there on the road along with these folks giving advice.
69Ford
Post by 69Ford »
My Dad loved his drill. My bodyman filled in thirty six holes and I'm still finding more. Dashboard, innerfender well's, camper mounts, etc, etc. He loved gadgets. JC whittney catalog was his bible. It took me months to get rid of all the gadgets and restore the truck to stock. He had a fifth wheel put in by a hack that welded the mounts to the frame and torched though a rust free box. Some of the worst welding I've seen. Oh well I still have the truck I grew up in and the memory's will live on because my dad was the PO. I will always miss him.
hillcountryflt
Post by hillcountryflt »
Might be kind of the wrong thing to do, but on my 1969, I started looking for aftermarket wires under the hood and the dash and along the frame. The usual ones for poorly rigged trailer lights (this truck has a 240, light duty trans and it had rear air shocks, not your most likely tow candidate). In any event, I found this one red wire that ran from the rear tail lights to the plug near the master cylinder. Pulled it and my rear running lights quit working. Started troubleshooting. To this day, the only thing I could find was that the plug needed reseating.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
