You can see the part number on the box is the correct part number for my truck, but it does not look like the bearings that are normally offered under that number. The bearing fits over the shaft, and fits nicely into the race(?) in the back of the steering column tube flange (part #3511), but I can't figure out how it is supposed to be secured so that it doesn't slide down the shaft. Of course, the illustration clearly shows that the bearing goes into the front of part #3511.I'm sure that securing the bearing has something to do with the three threaded holes on the flat portions, but I have now way of knowing how to utilize them short of drilling hoes into the steering column. I'm afraid that I may have the wrong part, although the seller assured me that this part is correct for 1971/up F100/250 (4X4) Trucks and 1971/up B-F500/700 bus & trucks.
Sorry for my lack of knowledge. Any help is appreciated, thanks.
