Used wrong transmission fluid
- hmills
ok, I'm going to admit it. I put Dexron III in my 71 F100 (original C4) and realized my error after adding 3 quarts and turning the engine on to warm up. I suppose I could drain it and add type F but i guess it has already mixed. any recommendations?
- 390Nut
re: Used wrong transmission fluid
Flush and re-fill with new fluid is the only thing I can think of. I don't know what type of damage could be done, personally, hopefully someone else here will know more. Interesting subject, as I had a buddy do the same thing once. He just drained it out, added some fresh type F, ran it up to operating temp and then spent a few minutes driving around the block a few times. Then drained and refilled again. Don't recall him ever having any major problems, but it was quite some time ago.
`69 F100 390 4spd driver
- 68F250
I would drain both the transmission and torque converter. One quart of Dexron is enough to ruin the properties of eight quarts of type F. Dexron is too slippery and will ruin the bands and clutches unless your C4 was rebuilt with Dexron compatible parts.
Barry
- 68F250
That's not bad but it will shift harder. Trick-shift as such fluids are type F.
Barry
- 390Nut
Re: re: Used wrong transmission fluid
Ouch. That dont sound too good at all. Didn't realize it was so incompatable with the type F.68F250 wrote:I would drain both the transmission and torque converter. One quart of Dexron is enough to ruin the properties of eight quarts of type F. Dexron is too slippery and will ruin the bands and clutches unless your C4 was rebuilt with Dexron compatible parts.
thanks for Tranny Fluid 101
- 68F250
You're welcome guys but I don't think that's what hmills wanted to hear.
I have a Ford service training manual on transmissions and it goes into a lot of detail on the properties of type F vs Dexron with charts and graphs.
Incidently, from '78 - '81 Ford reengineered all their automatics to run on the GM type fluids. It was unofficially called the "anti-clunk" program because customers were complaining that the Ford transmissions were shifting too hard.
Barry
Barry's got all of it right. Do a complete flush. It's real easy. First drain and clean the pan. Put the pan back and fill wilth fluid leaving the funnel in place. Then remove the return coolant line to the trans and clamp on a length (I have 8 ft.) of clear tubing. Run the tubing into a 5 gal bucket. Start the engine and the trans will pump the fluid out for you. Add a quart when about one has been pumped out. There should be about 4 qts in the pan so you shouldn't go dry on fluid and damage anything. My C6 holds (I think) 14 qts so I pumped through about 16-18 for good measure. I've done this with 4 vehicles and it works great.
72 F100 2wd 360 C6 Custom w/factory PS.
- 71-F-250SC-72-F-250C
I did that once. It cost me $800.
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic.
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
72 f-250 Custom
03 mach1 mustang
The transmission had to be rebuilt. Sorry I know you didnt want to hear that. I didnt realize that I had the wrong kind until I drove it about a day. So you might still be good.
72 f-250 Custom
03 mach1 mustang
72 f-250 Custom
03 mach1 mustang
- DuckRyder
One other thing.
If you have not moved the shifter out of park DO NOT!
If you did, you will have to do the same when flushing.
If you drove it... That is bad...
- rjewkes
why mine has ran on Mercon/dexron III for three years still shifts still doews everything and no band material in the pan yet? Maybe i got one that was built with dexron compatable stuff?
- DuckRyder
Must have been or you would probably be walking...rjewkes wrote:Maybe i got one that was built with dexron compatable stuff?
See Barrys post for "why".
