69 f250 360fe oil pressure
Hello everyone, I'm new here and have been having trouble locating a spot on my 360 FE to hook up a mechanical oil pressure tester or gauge. Any one know a good spot that's not near the oil filter? Thanks for your help and advice.
- Ranchero50
Re: 69 f250 360fe oil pressure
Nope, oil filter is the easiest spot to use once you get the original sender out of the way. Just install a pipe nipple to gain better access to it if you have power steering.
Awesome. I was told that the bulb that's there is a temp sensor. Man were they off. Samsonite! Thanks for your help
