Has anyone else had the experience of a cold transmission holding a shift longer than normal or jerky between gears?
I have noticed that if I don't let mine warm up for a good ten minutes in the mornings that are 30 or below that when I do leave it holds or jerks a bit. Warm temp is fine.
Any takers? Thanks.
BRRRR...
- twerp
BRRRR...
~Michael~
www.dream-logic.com
"It's a whole lot easier to kick down someone's sandcastle than it is to build one... So keep building..."
www.dream-logic.com
- newtothefordgame
re: BRRRR...
Transmission seals get old and hard--then don't do their job when it's cold. It's caused by low fluid pressure because it's leaking past the seals. I've never really had the problem personally but an OLD c6 truck that a neighboring business has does the same thing, or won't go into gear at all until it warms up. It's been doing that for years and it's still running but it's not exactly a GOOD situation.
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
69 F100 300I6
91 Bronco 351
- newtothefordgame
- mrung0wa
re: BRRRR...
When you had your Tranny "rebuilt" the gaskets, seals, bands, steels all got replaced. I'll bet that your case/core/hard parts are the same ones, Right?
A hydrostatic transmission relies on very high pressure and requires close tolerances. When your tranny is cold there are some gaps that with an increase in heat they expand, hence your gaps disappear and it's a happy transmission....
Lawrence
Lawrence
- marz68
