Front and rear wheel studs
Ohgoose
Post by Ohgoose »
I have a 67 f100 and will be converting the drum brakes over to disc front/rear using a Master Power brake set. I will be using steel rims like original and want to change out the studs while I am rebuilding everything. So what length wheel studs should I use for both the front and rear. On several threads I see that the front and rear are different for the drums but what about discs? Thanks
tnlprt
Re: Front and rear wheel studs
Post by tnlprt »
It all depends on the brake rotors
Till you have the rotors in hand to measure ...It would all just be speculation
