single or double flare?
- fonfixer
Is the hard brake line that runs across the rearend a single or double flare? I'm in the middle of a reared swap and figured I'd change the brake lines out while everything is out in the open before the new reared goes under the truck.
1967 F100 swb 240 single barrel, manuel choke, three on the tree, style side
1967 F100 swb 240 single barrel, manuel choke, three on the tree, flare side
2011 F150 Crewcab Lariet w/Ecoboost (runs like a scalded dog!)
2019 Transit
2019 Transit
Re: single or double flare?
Double flare - here is the tool I use for double flare. http://atdtools.com/5480
- flyboy2610
ALWAYS double flare the brake lines!
