More steering/wiring questions
chvyeatr
Post by chvyeatr »
Hey guys,
I posted this in the wiring section and not getting any answers. Maybe here!
The column in my 1969 f250 Camper was at some point replaced with a later 70s tilt column and lots of parts were left off in the transfer.
I found a 67/68 column in a f350 that was totally complete from rag joint to horn ring and I'm trying to finish this re-conversion.
The problem is the wiring harness plug on the 67 column does not match the plug on the 69. Below is what I have:
1969 plugs under dash that where disconnected from column, 8 wires in:
open------(2) red/blk stripe------------lt blue
(2) wt/lt blue -- (2)grn/wht sripe---- lt blue/ yellow strip
stripe
plug2: a two port plug with: orange/purple stripe------- blue/ yellow stripe
The plugs on the 67/8 column are:
open----------yellow/brwn stripe---------------red/blk stripe-----------------purple
green----------wt/blue stripe---------------------green/wt stripe---------------purple/yellow stripe
plug2: this comes from the neutral switch-
black/red stripe---------------black/red stripe--------------red/blue stripe----------------red/blk stripe
Thanks in advance for help on pairing these up!
GP
sargentrs
Re: More steering/wiring questions
Post by sargentrs »
Replied to your original post in Electrical. Good luck!
