C4 or a C6?
C4 or a C6?
What automatic would most likely be behind a 352 FE in a '67 F100?
-Braden Day
1969 Ford F-250 4x4 Highboy
1987 Chevy 4x4 1/2 ton
- flyboy2610
re: C4 or a C6?
Probably a C6.
- DuckRyder
re: C4 or a C6?
I agree FMX or C6 (not a C4)
re: C4 or a C6?
what is the difference between fmx and c6 are they not the same?
69 F-100 2wd 360 cid C6
- Comet
re: C4 or a C6?
They are not the same. C6 is a heavy duty tranny. I have heard that FMX's are getting hard to find for parts nowadays.
re: C4 or a C6?
seems like alot of 68 and back 352's had FMX's but it could be either best way to tell is crawl down there and look at the transmission pan if it a L shape then its a c6 if it more square then it a FMX i seriously doubt it's a C4...hope that helps.....
"Gas' Guzzler fer life" "Southern Pride""It's not what you buy it's what you build"
re: C4 or a C6?
According tho the oil pan it is a C6 but in everything I have read on the FMX came with a V8 in '67. But judging by a partially removed cross member the C6 was added later. The problem now is the thing leaks but I think it is just the pan gasket.
-Braden Day
re: C4 or a C6?
i'm sure you know this but pan gasket is a super easy fix...can pick one up for a c6 at any parts store....you prolly know that though....considering your familar with chevys....(week drive trains).... so am I... just a thought...
- flyboy2610
re: C4 or a C6?
Just be sure you do noy overtighten the pan bolts on that C6. The original pans were made from thin sheet metal and overetightening the bolts will distort the flange, making it nearly impossible to get a good seal.
You can get a pan made of thicker steel here:
http://www.c6-c4.com/
re: C4 or a C6?
My 67 F100 original has a 352 and C4 from the factory. The rating plate crosses over to a C4 in the 67 ford truck service manual also.
I'll be upgarding to a 390 and C6 soon.
- 68F250
re: C4 or a C6?
Ford never made a C4 to mate to the FE series engines, it's gotta be a MX (heavy duty version of the FMX) tranny, the code on the rating plate only means an automatic, does not specify which one.
re: C4 or a C6?
I stand corrected... After crawling under there it is not a C4 on my 352. The shop manual codes it as "automatic C4" but that's probably because there is no code for a MX-HD which is what I have.
