New to the forum and I recently bought a 1970 f100 long bed with plans to restore it. I'm slowly tearing it down to the frame and I noticed the very front crossmember above the twin I-beams is damaged. How concerned should I be and what options are available. I'm assuming I can replace it if I can find a donor, but should I try to straighten it? Replace it? or just leave it alone? It doesn't appear to be interfering with the suspension, but I wonder if I'm going to have alignment issues or other problems. Any thoughts would be greatly appreciated.
Damaged front crossmember
Re: Damaged front crossmember
I'd say it would be a good idea to take it to a frame shop.
1967 F-100 4x4 custom cab.
It simply looks like something was run over at some point. Many 4x4's do stuff like that all the time. IMHO, I'd not worry about it, try to straighten it a little on my own, and only look closer at it if you had an inability to align the front end. I've had a truck or two and multiple jeeps look like, or worse, than that, and never had an issue.
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- 69Ford
I would closely examine your I beams to make sure they were not hit also. I agree with an earlier post take it to a frame shop.
Thanks. I don't see any damage to the I beams and the frame sits level both across the frame rails and each rail vertically. It's not currently in a state where I can get it out, but once I get the bed and cab off and get things cleaned up I probably will take it to a frame shop for an assessment. It does look like someone ran over something at some point and from the looks of it more damage wouldn't have surprised me but I don't see anything else. I will look closer as I get it cleaned up.
looks to me, like someone used that as a jacking point.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
- Jacksdad
It does look like someone jacked it up on the crossmember without using a block of wood or something to spread the load - and tried a couple of times judging by the numerous dents. If the I-beams are straight and original, I don't see how the crossmember could be the only thing taking a hit in a collision.
I hadn't considered the jack theory. I don't know much history on the truck. I can't say if the I beams are original, but they do appear straight and undamaged. It originally came from Texas and was built with a 240. At some point the 240 got replaced with a 300. I took some pictures by a local body/frame shop today and they thought it's mostly cosmetic. They suggested heating and bending it back out to look as original as possible. I didn't see any glaring issues with fit and alignment of body panels before I started disassembly and as previously noted it sits level. I will see how square it is when I get the cab and bed off.
