Info on driveshaft
- spartman
Info on driveshaft
I was thinking about putting a 4 speed in my truck.
I have the tranny and it looks like it is either a T-18 or a T-98.
The housing on top says T-98 but according to my sources it could be either one underneath.
Anyway does anybody have, or know any info on a driveshaft for the short wheelbase trucks?
Any help would be greatly appreciated here.
re: Info on driveshaft
Good choice. Junkyard. Or get one built.
T98 and T18 are about the same. T19 has a synchro for 1st.
You'll like 1st gear. You can pull houses over!
- spartman
How much should one expect to pay for one out of a junkyard?
The closest ones to me in town don't carry anything that old and the one pick and pull I could check isn't open until after the snow melts and the ground firms up again.
ALSO what are the specs of the driveshaft? IE how long, how big around?
If I get one made I want to have some factory specs to compare to.
Thanks guys
Thanks guys
- flyboy2610
I won't be using the driveshaft out of my truck, which has a T18. It is a two piece driveshaft. You could probably have the rear section shortened, unless the shortbeds used a 1 piece shaft
Let me know if you're interested.
- flyboy2610
How about $20? Plus $15 for the shifter from the other post?
I'll have to pull the driveshaft to get a weight for shipping, that may be a couple days.
Shortbeds do use a one-piece driveshaft with a slip-yoke in the transmission.
- flyboy2610
Yea, I kind of suspected that might be the case.
- mrung0wa
If you have a custom one (driveshaft) made FYI: Remember the strength of the driveshaft is in it's diameter (tubing), not in it's thickness (gauge). :cents:
Lawrence
Lawrence
