Hey There,
This is a shot in the dark but I'll try anyway. I'm trying to locate an original ford adapter kit for removing the front coil springs on a 1969 cougar. I believe that mustang would have also used this tool. Any old ford mechanics out there that might be willing to part with one??
Thanks Much,
Ford Tool Wanted
Re: Ford Tool Wanted
I think Falcon's and Mustangs used this same tool. I bought a modern day remake years ago on ebay. Could've made it myself had I known what it looked like. (I can't part with mine, I still have several of these cars in the stable).
Mine looks just like the one in this thread:
http://forums.vintage-mustang.com/vinta ... tangs.html
and similar to this one on ebay:
http://www.ebay.com/itm/65-73-Mustang-S ... 1195370724
or, money.
or, money.
- HIO Silver
Your local Autozone will likely have one to rent.
If you can fab, it is relatively easy to make one.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- 48prerunner
When I did mine 30 years ago I just used the chain hoist down thru the top of the shock tower and a bar across the coil spring, but when you are just out of high school you make things work.
Yea, I can relate. I did a LOT of things back when I was a lot younger that today I'm thinking how the heck did I do that or why did I do it that way?? Today however, I'm a lot more aware of how I approach things and put a little more thought into what I'm taking on. Safety is BIG in my mindset right now and I formulate a plan before making any repairs. Being older & wiser now makes me look at things a whole lot different!
Cheers!
Cheers!
we used to make 2 plates and 4 threaded bolts 4 nuts ,just tighten till spring can come out,but we also use too pull transmissions out by hand with no jacks,boy lucky I can still walk,
go on ebay they have the compressor spring tool you need for $15.00 you cant beat the price there are many on there it will save you from getting teeth knocked out. good luck
