I recently got a Marti Report and it told me my truck came from dealer 75A438. I believe this would be a dealership in Arizona, since the truck had been there it's entire life, but I would like to confirm that. Does anyone know what dealership this is or is there a list somewhere of the dealer codes? The DSO on the vin tag is "75".
Thanks,
BJ
Dealer Codes
- hdman90
Dealer Codes
Re: Dealer Codes
I just found mine on here 10 minutes ago after I found my original owners manual, logged in, saw your post!
http://www.oneownercollectorcar.com/ind ... -dana-chev
- hdman90
Re: Dealer Codes
That does help, but they do not list a dealer code, which is what I was given on the Marti report. So somehow I have to figure a way to match the two up!
Re: Dealer Codes
Yeah they list a lot of dealer codes, but not every place. Couldn't find yours on there after searching either.
- hdman90
Re: Dealer Codes
Bump... curious if there are any updates on this topic. Or if anyone has new info...
Re: Dealer Codes
Did you get the deluxe report? If you did it the dealership name and address should be on it........the report for mine has it right below the DSO item number..........BTW got the door panels you sent me repainted and the speakers in and they turned out great........
1997 Honda CBR 900RR
- hdman90
Re: Dealer Codes
I did not get the deluxe report, however it has been a year and a I am seriously considering upgrading. For a mere $23 (I think) I can upgrade.Ohiotinkerer wrote:Did you get the deluxe report? If you did it the dealership name and address should be on it........the report for mine has it right below the DSO item number..........BTW got the door panels you sent me repainted and the speakers in and they turned out great........
And glad to hear! Send me pictures of how they turned out if you get a moment!
- Manny
Re: Dealer Codes
Always wanted a marti report just kinda a mess as mine is a 67 2wd body on a 68 4x4 frame... Have to get two..
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
