Does this sound like my throwout bearing is bad..?
Im holding the recording device above transmission hump inside the cab. The noise changes as I move clutch in and out. This is in nuetral with a np 435 and 352.
The sound file is here:
http://s30.yousendit.com/d.aspx?id=2VHV ... BKGG2TQ1N7
Throwout Bearing?
Throwout Bearing?
When the going gets tough, your doing something right.
- jor
re: Throwout Bearing?
Hey, this is a great way to get some diagnostic opinions. I think it does sound like a throwout bearing. In my experience, when they start to go, they make kind of whooshing sound when the bearing contacts the pressure plate. It gradually gets worse until it howls. Does the clutch engage and disengage properly?
jor
jor
Yes, it engages and disengages all the way and does it smoothly. There is a howl as well when I get going, however, that could just be the tranny. I have greased the bearing, but that didnt help.
I will also post a video of this when I can get it off the camera.
- jor
You can usually determine if the throwout bearing is going bad by depressing the clutch just until the bearing touches the pressure plate fingers. If it's making noise at that point, it is probably on its way out.
jor
jor
then yes it is going bad, becuase that is when it gets loudest, when it touches the pressure plate.
