Looking for a rear drive shaft for a 67-72 F-250 with 4wd and a Dana 24 transfer case. This would be part number C7TZ-4602-BG. The length from end of hole (drive shaft side) to end of spline is 34-13/32".
Thank you.
4x4 Rear Drive Shaft
- hdman90
- basketcase0302
Re: 4x4 Rear Drive Shaft
Probably highly unlikely to find the OEM part number your looking for. I've been working of our Ford trucks since the early 70's and maybe seen zero to one driveshaft that ever had a Ford OEM part number stamped on it."hdman90"]Looking for a rear drive shaft for a 67-72 F-250 with 4wd and a Dana 24 transfer case. This would be part number C7TZ-4602-BG. The length from end of hole (drive shaft side) to end of spline is 34-13/32".
Thank you.
![Sad :(](./images/smilies/icon_sad.gif)
Typically how you'd approach this is to have it custom built which will also be a lot easier on your wallet as they too will balance it, (once you know the end cap / U-joint sizes) from a local driveline shop. I'm sorry I don't know the area better but maybe google driveline / drive shaft / (don't rule out finding the driveline shop from a transmission shop who uses them a lot either).
Try this link to help ID it:
http://www.daytonclutch.com/driveline/how-to
