delay wipers
delay wipers
I would like to put delay wipers on my 72 f 100 any ideas ?
thanks
Bob B
thanks
Bob B
- Ranchero50
Re: delay wipers
Get the intermittent switch and black module box out of a late 80's pickup. Cut @ 1/2" off the shaft and it's a plug and play install.
- hdman90
Re: delay wipers
I believe some '73-'79 trucks had them too, should also use the same steps as described above.
- hdman90
Re: delay wipers
- basketcase0302
Re: delay wipers
Correct-78' and 79' were the only two years of the dent era that offered them."hdman90"]I believe some '73-'79 trucks had them too, should also use the same steps as described above.
I installed the 79' delay on my last bump and it was such...an improvement-to not have to be constantly reaching down to turn the switch on and off when it was sprinkling rain.
- FLASH 1
Re: delay wipers
delayed wipers where on 73-79 trucks and 78/79 Broncos as a option and for 20 years + have been using them AND Selling them to be used on 61/66 trucks as well
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
Re: delay wipers
Morning,
Being I live in the Great North-Wet, this was the best Mod I ever installed on truck.
I got the delay box and switch from a 1976 1/2T 4x4 many years ago.
Thanks,
Lee
Thanks,
Lee
- basketcase0302
Re: delay wipers
Never saw them on the 73' thru 77' dent era trucks Tom. When I found mine it was using a search engine of 78' thru 79' delay wiper switch."FLASH 1"]delayed wipers where on 73-79 trucks and 78/79 Broncos as a option and for 20 years + have been using them AND Selling them to be used on 61/66 trucks as well
Even half way down here on the factory "options dealer sheet" it only lists the two speed wiper with no mention of delayed wiper option.
http://www.fordification.com/library/_d ... c68-me.jpg
And here Kieth has no mention of the early years having it either?
http://www.fordification.com/tech/wiperdelay.htm
Any other sources for the 73' thru 77' dent era wiper delay information?
Re: delay wipers
Hi,
I went to Auto-Zone's website and searched for a Intermittent Wiper switch for 1976 F100.
Then there is a Tab for "Vehicle Fitment". It lists 205 Fords that used this switch.... showing trucks back to 1973.
https://www.autozone.com/electrical-and ... 5_149777_0
Lee
Lee
- cdnwillyg
Re: delay wipers
Lee that maybe the switch but to my understanding there is another part that does the delay, it's a black box that works with the switch.
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
Re: delay wipers
That is correct. You need the wiper delay governor D3TZ-17C476-A. Good luck finding one cheap!
Re: delay wipers
I will be heading to my ford dealer this am to see if that wiper delay governor is still able to be ordered also I need to
find the part number of the wire harness that goes with these parts hope someone knows
thanks
Bob B
thanks
Bob B
Re: delay wipers
Make sure you get the right switch. The delay switch and the standard switch are different. You want the D1OZ-17A553-A. The harness is integrated into the delay governor so if you find that, the harness should be included.
Re: delay wipers
Good information thanks
Bob B
Bob B
- basketcase0302
Re: delay wipers
"FITMENT AND OEM BEING TWO TOTALLY DIFFERENT DEFINITIONS LEE!"Lee"]Hi,
Lee
I CAN GO TO AUTOZONE'S WEBSITE AND SEE "FITMENT" OF 38' SUPER SWAMPERS FOR MY OLD 76' BRONCO!
But they were never OEM.
