https://rover.ebay.com/rover/0/0/0?mpre ... 3020117704
Guys thoughts on this welder? Seems like a lot of features for decent money. 60 on duty cycle seems good compared to a bunch of the cheaper brands. I’ve posted before looking for welder but I cant justify spending big money on something that will be used so little. Floor pans, motor mounts and a C notch is what I’m looking at doing. Thanks ahead of time.
eBay welder
- gregamorton
eBay welder
- Ranchero50
Re: eBay welder
My dad gave a good example years ago about a stereo that had 15 components for under $100, that each part was very cheaply built. Swap part for function and I wouldn't expect it to last or do what you want for long.
- gregamorton
Re: eBay welder
I understand that thought process. I’ve been looking for a used name brand for decent price no luck so far.
Re: eBay welder
Same one is available at your local Home Depot. https://www.homedepot.com/p/AMICO-POWER ... /304254567 Only $50 more but at least you'd be able to talk to someone locally if there was a problem.
Re: eBay welder
I wouldn't even consider it myself. Buy it once and never regret.
Spend the most you can afford (just like buying a truck)
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
- hfdco4
Re: eBay welder
I have my Harbor Freight mig welder for the last 5 years. Only thing I have done to it is replace the tip. I use it to do sheet metal and Frame work. It has four heat setting and gets good penetration on the frame with ok duty cycle.
FE390PC
FE390PC
- Jacksdad
Re: eBay welder
I don't pretend to know your skill level, but Tig isn't an easy process to learn, and stick isn't really well suited to sheet metal. I'd recommend a Mig for the things you want to do - it's way more versatile and user friendly. If you're set on a new welder and you don't mind taking a chance on a cheaper unit, try Harbor Freight. Their newer welders aren't too bad, and at least you'll have a physical store to return it to if you have problems.
A used name brand welder would always be my recommendation, but I understand that only works if someone's selling one in your price range. And whatever you get, spend the extra to get a gas set up.
Re: eBay welder
Forget those cheap ebay welders. They are not worth the money and hassle.
