more rear end questions
F-100Ranger
Post by F-100Ranger »
I have a bunch of questions about the rear ends offered by Ford. How common were the the "locking" ones? How well do they perform? Is this something desirable for a street truck rebuild?
I would appreciate any input from those of you with experience with gearing know-how.
heep70
re: more rear end questions
Post by heep70 »
Dana 60s came with Trac-Loc and Power-locs. The Power-loc is the better of them, but the Trac is easier to find. The Power-loc takes one clutch pack to rebuild it and the Trac-loc takes two packs. You can get either the stock smooth surface clutch packs or get the more agressive style abrasive clutch packs. D60 fullfloaters axles were built in F250 and heavier pick ups and the D60 semifloater were offered in the F100 and newer F150 pick ups.
I am not sure what 9 inchers came with.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
NM5K
Post by NM5K »
I wouldn't consider it a "must have" for a street truck. MK
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
heep70
Re: re: more rear end questions
Post by heep70 »
NM5K wrote:I wouldn't consider it a "must have" for a street truck. MK
Me neither, with a locker you will end up with more tire ware and less gas milage.
I put the aggresive clutch pack in my powerloc and lost one mile to the gallon and everytime I turn a corner my tires cherp. No regrets when I am up in the hills. :)
Greg
cobraF100
Post by cobraF100 »
What do you mean as a "Street Truck"?
Stop light to Stop light,Friday Night Street Truck or a worker?
Alot of the OEM Units where not that good for anything other than a Normal Driver as they didn't hold up well to "Hot Rodding" them.
They did come out with an Extra Heavy Duty (still an Ford OEM part) Units and they were much better than the Stick Units.
You have a wide open market to chose from.But if it was me I'd go:
Street Truck everyday driver-True Trac or Trac Loc.
If it's going to be something that your really going to play with and get on it hard then go with the Detroit Locker as they are the Strongest and will take Pounding..
Chris
Never Forget Our Soldiers
F-100Ranger
I have a piece of property in the country. Every time I tried to drive into the field, the one wheel drive spun and I had to retreat. I could use the extra traction.
I still haven't made my final decision, but am checking into it now that I've got the bare frame. I appreciate all the input and collective wisdom out there.
heep70
Post by heep70 »
cobraF100 wrote:What do you mean as a "Street Truck"?
What about a spool? Now that is to much. :lol: :lol: :lol:
Greg
cobraF100
Post by cobraF100 »
In my 66 Mustang I had a Full Spool and it was Fun :twisted: but it was also a big pain in the rear both rears mine and the cars.
Not to mention that the Wife just about Killed us at the Pigeon Forge Rod Run 2 yrs ago.Partly my fault as it was the first time she drove it with the Spool.. :roll:
I Sold it to my Best Firend about 2-3 months ago and he has already called (his Wife) and told me a few things about it....She was a little :x as he just about took out a Mail Box and some kids going around a Sharp Corner.
He nailed the gas right in the middle of the corner !!!
Chris
NM5K
Post by NM5K »
I have a piece of property in the country. Every time I tried to drive into the field, the one wheel drive spun and I had to retreat. I could use the extra traction. >>>>>
I had the same problem last summer at field day in a big wet field. I wanted to drive my truck up a simple hill to the flat field, that wouldn't bother a VW on 2 cyl's normally, but it was so wet and mushy there was no way I could make it up the short grade without digging in my right wheel. Even using granny 1st with as little throttle as possible. And I *have* limited slip. But someone, I think Willowbilly, said the clutch disks might be shot.. I'm not sure which version I have...I have the dana 60 full float in the 68 f-250 with limited slip whichever type it uses... It must be about wore out as far as the clutches, as it didn't seem to do me much good at all. I've never had any chatter problems or anything..Maybe thats why... :hmm: MK
F-100Ranger
OK, you have me curious. What's a spool? Never heard of it. How's it work?
heep70
Post by heep70 »
It is basically a solid carrier that provides 100% power to both back wheels at the same time no matter if you are turning or going straight.
You don't want it. They are a pian in the butt unless you drag race or rock crawl.
http://www.markwilliams.com/pdfcat/pg30 ... ferentials'
Greg
willowbilly3
Post by willowbilly3 »
I have heard that snapping an axle under acceleration with a spool is a real experience.
In about 87 I put the limited slip in my F-250 D60 2wd. It made a huge difference in how I got around. Especially on winter streets. It mad all the difference in the world, like from hating the truck to just loving it. Yes it was just the clutch type but worked great with the stock 300 T-18. I take it out in the woods all the time and it is amazing where that old truck can go. I must say after maybe 80,000 miles it doesn't hook as good as it used to. I imagine the clutch pacs are getiing worn. For all out I would go with a torsen-gleason or maybe even an air locker.
F-100Ranger
rear end prices
What's the going rate for a locking rear. I would appreciate some feed-back from those of you who have some experience. Just trying to get a feel for what 's a good buy.
thanks in advance.
Kaylle
Post by Kaylle »
So far most of the post have been about Dana rear ends. More then likley you have a Ford 9" 28 Spline. If so for less then 200 bucks you can get a Lock Rite form jegs. http://www.jegs.com/cgi-bin/ncommerce3/ ... rmenbr=361
I was going to install one of these on my 66. But when I took the rear end apart I discovered it was a Ford 9" traction lock. I replaced the clutch pack. Then sold the Lock Rite to a friend with a 72 F100. Basically you ad it to your exisiting diffrental. He loves it and said it was not to bad to install. I had a nother buddy who bought a 9" rear end(pumkin, center piece) off of ebay for about 400 bucks, it had some type of locking set up in it.
Kaylle Jonas
67 F100 SWB 429 C6
66 F100 SWB 390 Car 4spd Toploader 3.5 Traction Loc
65 F250 LWB 352 Granny 4spd
Monroe NC
heep70
Post by heep70 »
Greg
