Rear cab mount bolts
beejaytx225
Post by beejaytx225 »
This is a picture of my driver's side rear cab mount. The passenger side looks the same. Isn't there supposed to be a nut on these studs?
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Central Texas
cep62
Re: Rear cab mount bolts
Post by cep62 »
I believe that style of retainer is threaded going up into the bushing.
sargentrs
Post by sargentrs »
:yt: And a royal pain to break loose with 50 years of rust welding it together. I used vice grips on the outer edge of the lower flange to hold a backup while working the bolt from inside the cab. Spray liberally with PB Blaster or equivalent and let soak. Repeat as necessary. Be gentle and work the bolt a little at a time back and forth. Once the bolt is out, spray inside and let soak. The top and bottom pieces have interference fit tubes and a little emboss that "click" together. They rust together like they're welded but with patience and tenacity they'll come apart.
beejaytx225
Thank y'all, it had me concerned lol. Good to go :)
360 w/C6
Peacock Blue
Central Texas
CH3NO2
Post by CH3NO2 »
sargentrs wrote::yt: And a royal pain to break loose with 50 years of rust welding it together. I used vice grips on the outer edge of the lower flange to hold a backup while working the bolt from inside the cab. Spray liberally with PB Blaster or equivalent and let soak. Repeat as necessary. Be gentle and work the bolt a little at a time back and forth. Once the bolt is out, spray inside and let soak. The top and bottom pieces have interference fit tubes and a little emboss that "click" together. They rust together like they're welded but with patience and tenacity they'll come apart.
My :2cents: . There is no equivalent to PB Blaster !!
sargentrs
Post by sargentrs »
Much better than WD40. Here's an interesting comparison from awhile back.
http://www.fordification.com/forum/view ... hp?t=44934
beejaytx225
That's actually a pretty neat study. Never would have thought of the home brew! Cool stuff 8)
360 w/C6
Peacock Blue
Central Texas
jzjames
Post by jzjames »
This thread has answered the question I have had for a long time. — Why doesnt my rear cab mounts have any nuts on the bolts? ive often thought I need to get down there and put some on :wink:
beejaytx225
I'm happy my inquisitive nature has helped someone :lol:
360 w/C6
Peacock Blue
Central Texas
sargentrs
Post by sargentrs »
One of mine was toast. I used one of the others as a pattern. Fortunately I have access to a laser and band saw at work. Cut 2 washers and 2 pipes, diffrrent sizes. Using long bolts, nuts and lock washers to mount.
jamesdfo
Post by jamesdfo »
Randy: Just spitballin' here.....If you weld a deep nut to the two big washers that will be underneath, if/when you have to take things apart at a later date, you can stick a deep socket on the nut, use an impact from the bottom, and have someone inside with a wrench holding the head of the bolt.......
James
HarleyJack
Post by HarleyJack »
You are onto something for disassembly. There is a video or two of where they make a "puller" to pop these apart. VERY good idea as it beats a sawzall by a country mile! Use the threading to your advantage.
sargentrs
Post by sargentrs »
jamesdfo wrote:Randy: Just spitballin' here.....If you weld a deep nut to the two big washers that will be underneath, if/when you have to take things apart at a later date, you can stick a deep socket on the nut, use an impact from the bottom, and have someone inside with a wrench holding the head of the bolt.......
James
Good idea! Thanks for the tip!
jzjames
Post by jzjames »
A useful pc. of information I came across on FTE. (They let me back on their site, I guess bygones be bygones)
This must be for the other type of body mounts/bushings.
https://www.prothanesuspensionparts.com ... e/6110.pdf
