67 with 79 tilt auto column American Autowire question
Ohgoose
Post by Ohgoose »
Looking for some help. I have a 67 that has a 79 tilt auto steering column (I recently rebuilt the entire column). I just purchased an American Autowire harness (67 harness) and want to know how to match the wires up with the provided male/female plugs ( I will be building the terminal ends and I need to know what the colored wires on the turn signal switch run to, to then match them up to the wires on the new harness) Also would like to know what the gear selector light wires to, to be active when the head lights are turned on. The previous owner had the old wiring so hacked together and the switch and lights never worked correctly. Thanks for any help.
basketcase0302
Re: 67 with 79 tilt auto column American Autowire question
Post by basketcase0302 »
"Ohgoose"Looking for some help. I have a 67 that has a 79 tilt auto steering column (I recently rebuilt the entire column). I just purchased an American Autowire harness (67 harness) and want to know how to match the wires up with the provided male/female plugs ( I will be building the terminal ends and I need to know what the colored wires on the turn signal switch run to, to then match them up to the wires on the new harness) Also would like to know what the gear selector light wires to, to be active when the head lights are turned on. The previous owner had the old wiring so hacked together and the switch and lights never worked correctly. Thanks for any help.
Memory serves me correct the Ford OEM wiring for the indicator lamp on the column was blue with a red stripe, (shown here).
http://www.fordification.com/tech/wirin ... -chart.gif
Here's the 67' Ford OEM wiring harness schematic regardless as it might help you:
http://www.fordification.com/tech/wirin ... iagram.jpg
And my 79' tilt was pretty straight forward using the 79' tilt tutorial here:
http://www.fordification.com/tech/tilt.htm
But...it will be hard for anyone here to help graft the wiring on this unless they have the aftermarket Autowire harness you're installing.
Ohgoose
Post by Ohgoose »
Thanks for the info and links - will take a look and let you know how it turns out.
basketcase0302
Lifetime retired HVAC tech here.
When there was a lot of "control wiring" in my line of work one techniques that always helped was to first wire/complete the obvious, (the ones you know of for sure) then work your way toward the remaining wiring. :wink:
