Torque Wrench Question???
capeclassics
Post by capeclassics »
When you are going to tighten a bolt to a specific torque setting what is the correct start point i.e. should the bolt be finger tight before you start torqing?or what?Thanks
BigRedTruck
re: Torque Wrench Question???
Post by BigRedTruck »
thats what I do. they won't register anything till you get a certain amount of resistance.
69 F-100 2wd 360 cid C6
heep70
Post by heep70 »
Start there and then I increase in increments of 10lb if there is a more then one bolt or nut. ie head bolts
ei, ei, oooooooooooooooo :D
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
flyboy2610
Post by flyboy2610 »
And if you are using a 'click' type torque wrench, be sure to set it back to 0 when you are doen. You sould not store those wrenches with tension on the spring.
