2wd lift kits?
Moderator: Doug Comer
2wd lift kits?
I am debating lifting my truck, but its a 2wd and I am keeping it that way. I see all 4wd kits, but no 2wd. How different are the coil springs between the two? Thanks!
- xxxtina63
re: 2wd lift kits?
Depends on the make and model of the vehicle. Going to assume that it's a bumpside, which presents a problem. Most companies start around the early 70's model years. A company called Fabtec, or Fabritec, I don't remember which one, makes 2wd lifts. Most of the time, the kits rely on longer (vertically) spindles, or, in the case of a twin I beam suspension, longer coils and I beam drop brackets.
My FORDification Photo Album
- lightning_msd
re: 2wd lift kits?
on overhaulin they overhauled an F250 2wd and gave it a lift, i thought it was a little lame but im not one to criticise others opinions. if you check out AEM supsension i think that they have a lift kit on there but dont quote me on that.
1967 F100 "Lexxi" 352
http://www.fordification.com/galleries/ ... ?album=482
re: 2wd lift kits?
Autofab will have what your lookin for!! But get yer wallet ready.$$$$$$$$$ ![Surprised :eek:](./images/smilies/icon_eek.gif)
lover of old fords
re: 2wd lift kits?
Yes autofab is expensive, because they cator to the desert racers. Full travel suspensions jumping over dunes, most other sites list to 1970, but i dont believe they are any diff, from 67 to 69. ![Smile :)](./images/smilies/icon_smile.gif)
lover of old fords
- boots
re: 2wd lift kits?
search the forum because there is a TON of stuff on 2wd lift kits. I made my own.. check my gallery.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
