Anyone know if that 4x4 crossmember is bolt in on a 2wd frame? Wondering if I should put one of those in my conversion from 2wd to 4wd.....(probably doesnt matter but looks alittle more beefier)
Todd
4x4 crossmember?
Moderator: Doug Comer
- zakt
4x4 crossmember?
1972 Ford F350 crewcab
![Image](http://www.fordification.com/galleries/albums/userpics/10045/350emblem~1.jpg)
- Wes
The cross member is different on a 4x4 so the front differential will not hit it. I think, but am not sure, you will have to move and or replace the front cross member.
here is a picture I have of mine
http://www.fordification.com/galleries/ ... ?pos=-5808
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them![Smile :)](./images/smilies/icon_smile.gif)
67 F250 High boy
69 Bronco
- zakt
re: 4x4 crossmember?
sorry didnt specify, the transmission crossmember. The 2wd engine crossmember will stay I will have a 12 1/2" lift in front, plenty to clear the 2wd engine crossmember ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- 460 crew
Mine were bolted on. ![Image](http://i85.photobucket.com/albums/k51/Crewzin70/trannycrossmoved.jpg)
