i need some info please
dssiegrist
Post by dssiegrist »
i have a 73 f 100 that came factory with a 360 3 speed i bought a 351 windsor with a c 6 for 125 dollars i swapped engine and tranny out but found out that the c 6 shift linkage is locked up wont move by hand so i was needing to know could i use the 3 speed tranny on the 351w and if so what do i need to get to get it bolted up and the bell housing will it match up since it came from a 360 block the engine runs great it has a 283 cam and lifter set and a four barrel holly carb with vacuum secondaries :D
basketcase0302
Re: i need some info please
Post by basketcase0302 »
dssiegrist,
The 360 engine is of the "FE" family, the 351W is of the "Windsor" family.
Two different engine families, I don't believe they will bolt up without changing the bellhousing on the 3-speed.
Here's a little more information:
http://www.fordification.com/technical-home.htm
Basketcase
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Why not just drop the pan on the C6 and see where the linkage is binding up? It might be something very simple to fix.
Jake11
Post by Jake11 »
YEAH! Keiths onto something. Why swap everything when it could be a 1/2 hour fixee. Good luck, Jake :)
dssiegrist
well i do need to get other things for the auto to work like tranny cooler and driveshaft im low on funds right now but i guess ill drop pan cause i really want an auto for fuel saving reasons thanks for all yalls info
