'67 F100 stepside - full resto new photos 03/03/2013
67nukeford
Re: '67 F100 stepside - full resto project storyboard
Post by 67nukeford »
Looking good so far! I did the same, with the baggies and index cards. I also have a bunch of boxes for each are where the parts are from.
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
69F110
Post by 69F110 »
Looking good!
Steve Davis
Pastor and U.S. Army Retired
tybob81
Post by tybob81 »
Remember to take lots of pics during the tear down so when it is time to put it all together you don't have to second guess yourself. I did and wish I would have posted it on photobucket too, because Wal mart lost my photos the developed!!
67mann
Post by 67mann »
Doing a little target practice while working on the truck :eek: :lol: :lol: looks like a good sized caliber---can't wait to get to my next place so I don't have to pack everything into the truck to go shoot :hd:
Moving right along on your progress---Are you going to strip down the frame and rust treat it
stephen44
Post by stephen44 »
67mann wrote:Doing a little target practice while working on the truck :eek: :lol: :lol: looks like a good sized caliber---can't wait to get to my next place so I don't have to pack everything into the truck to go shoot :hd:
:D - thats an old hood i got for some welding practice - came with free holes !
and yes I am taking the frame all the way down and sand blasting it etc
thanks
Stephen
stephen44
Post by stephen44 »
so - it must seem like I have disappeared but I have slowly been rebuilding teh rust
here to remind you was what i started with
thanks
Stephen
stephen44
Post by stephen44 »
and here is where I am at..
thanks
Stephen
72stepside
Post by 72stepside »
Those cab mounts look fine to me. Yeah, they are different that what I have in my project thread, but it looks like they'll work.
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
69FLATBED
Post by 69FLATBED »
Dang Stephen, that was a fast teardown! :thup: keep up the good work.
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
stephen44
Post by stephen44 »
72stepside wrote:Those cab mounts look fine to me. Yeah, they are different that what I have in my project thread, but it looks like they'll work.
good - thank goodness for that :thup:
- Stephen
thanks
Stephen
stephen44
Post by stephen44 »
69FLATBED wrote:Dang Stephen, that was a fast teardown! :thup: keep up the good work.
thanks - as I am finding out - the tear down is the easy bit :D
- Stephen
I got guns - paint & filler delivered today - so I can see light at the end of the tunnel
-(as the old joke goes - let's hope it isn't a train :lol: )
thanks
Stephen
stephen44
Re: '67 F100 stepside - cab corner replacement - pics
Post by stephen44 »
I thought I'd document how I did this - as you cannot buy the inner corners - and this might help someone as I could find no hints on the best way of doing this. Now remember - I have no metal working experience - so i am not saying this is the right/best way of doing this - but this seems to have worked for me.
this is what i started with (other side)
i decided to butt weld - as i knew i could get to both sides - I took the cut too the point of good metal and since the replacement part did not fit exactly - just shy of the mold line.
thanks
Stephen
stephen44
Post by stephen44 »
I then welded and ground both side
I made the inner corners from the left over outer corner - I flattened it with the BFH
- for the beading on the original inner corner - i cut back to good metal and then slit the beads and flattened to give me an edge to butt weld.
I epoxied all the insides to give them some protection before welding on the inner corner.
I shaped the edges over a wooden table and a stone paver
thanks
Stephen
stephen44
Post by stephen44 »
I continued shaping till I was happy with the fit and then welded up
I kept on welding until all pin holes had been sealed and then ground down
thanks
Stephen
stephen44
Re: '67 F100 stepside -cab corner replacement - pics
Post by stephen44 »
I also started sanding the cab down
thanks
Stephen
