E85?
E85?
I mistakenly filled my 2005 F150 with E85. Will this harm anything to burn through this tank? I have read that F150's did not use E85 until 2006.
- forrestbump
Re: E85?
I'd drive a lot and don't let it sit too long. As soon as your tank is down 1/4 add regular gas to top it off. E85 is tough on non E85 parts.
Larry
Larry
- randyvines
Re: E85?
I personally would drive this tank out ASAP
- BRUTUS_T_HOG
Re: E85?
you will be running lean under load if your fuel injectors can't keep up with demand.
are you sure your engine is not flex fuel?
ASE Certified Technician
Re: E85?
You may want to inspect any soft parts in the fuel system after its flushed out. The alcohol can be a little harsh on them.
- Effie
Re: E85?
The alcohol can definitely be rough on the rubber parts. The fuel pump and lines are all different on the flex fuel vehicles. Also, the alcohol can attract moisture.mrollings53 wrote:You may want to inspect any soft parts in the fuel system after its flushed out. The alcohol can be a little harsh on them.
I looked into this a lot when we were gonna run alcohol in the race car and it was talking about having two tanks, one for alcohol and one for gas. So just before you park the car to put it up for the week, you're supposed to run a little gas through it, due to it attracting moisture and being hard on the rubber lines.
- woods
Re: E85?
It does have ill effect on rubber parts, but one tank is not going to do damage if he does not let it sit and adds gas to it as it goes down. It's already 15% gas, the more he adds the less likely it is to do anything.
