There were a number of different boosters on the '67-'72 and '73-'79 model trucks. Not all Dentside ('73-'79) boosters are a direct swap to the '68-'72 model trucks, without out swapping to the Dentside pedal (s) and pedal hanger.
1967 is an odd - ball year and only a '67 specific booster will work with '67 specific pedal and hanger.
If you are pulling a booster from a wrecking yard donor truck, you'll need the booster (to turn in as a core for a newly rebuilt booster), the booster to firewall mounting brackets and the plastic boot that goes between the back of the booster to the hole on the engine side of the firewall.
Boosters will come in varying diameters and will either have a single-diaphragm or dual-diaphragm.
This is an 8-3/4" diameter Bendix dual-diaphragm booster I installed in my '69 F-100 Ranger, from a '75 F-350. --I swapped the donor booster for a newly rebuilt unit. The boosters input rod connected directly to the pin on my stock '69 brake pedal.
For the past couple of years, I've been running the booster with my stock 4 wheel drums.
Currently, I'm installing disc brakes on my '69 F-100 that I pulled from a '77 F-100.
I replaced my 'conventional' cast iron master cylinder with a modern MC.
