Steering column schematic
I have a 73 steering column I'm putting in my 67 on a ps conversion are there any easy to read schematics to match wires up I will be cutting the connector off of old 67 column and wiring the 73 to it?
Re: Steering column schematic
According to the tilt column swap page in the tech section http://www.fordification.com/tech/tilt.htm
According to the the '73 wiring diagrams:
red/black stripes to brake light switch
green/white stripes to LH front turn signal
white/orange stripes to emergency flasher
yellow/brown stripe (I could only find yellow/black stripe to LH rear turn signal)
white/blue stripe to RH front turn signal
blue to turn signal flasher
blue/red stripe to "PRNDL" lights (you wont need the wire to the "PRNDL" light since you have a manual shift.)
green to RH rear turn signal
yellow/blue to horn relay
Not sure how this mates up to a '67 though. http://www.fordification.com/tech/wirin ... iagram.jpg You may not have to actually cut the harnesses. I was able to push out the pins in the male connector. You could just rearrange most of them and splice the rest.
