67 radius arms
67 radius arms
Does anyone make new radius arms for a 67 f100 or is this just a junk yard find. I have one that is on the questionable side and figure since I am rebuilding the entire suspension now is the time to swap it out. What years would be compatible if I cannot find a 67 set?
- 1968-f250
Re: 67 radius arms
When I was on the hunt for radius arms I was informed that radius arms from 67-79 will interchange. The set I found did come of of a later year truck and they were identical. Hope this helps!
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1957 Ford Fairlane 500 convertible (x2)
1979 Ford Bronco (x2)
1956 Ford Thunderbird
When the going gets tough, switch to power tools -Red Green
1964 F100 Short box
1968 F250
1972 F100 4x4
Re: 67 radius arms
Nobody makes these aftermarket, you'll have to find a good used one. The radius arms from '67-'72 are forged steel, the '73-'79 pieces are stamped steel. The later pieces will work, but they'll look different and require you to use the matching coil spring. It's better to just find one from a '67-'72.
Re: 67 radius arms
Thanks guys I figured the junkyard was the answer, but didn't know which years would work.
