Brake pressure differential valve
- 69f-100
I'm doing a complete brake system overhaul to my 69 100 2wd with 4 wheel drum brakes. I'm not 100% sure if this is what it's called, but can and does this valve need to be rubuilt? If so where might I find the parts to do so?
- Ranchero50
Re: Pressure differential valve
You can take it apart and make sure the slug in the middle moves so it'll make the lamp light up when one circuit loses pressure.
- 69f-100
Ok, I'll check it out. If it doesn't, do they have replacements?Ranchero50 wrote:You can take it apart and make sure the slug in the middle moves so it'll make the lamp light up when one circuit loses pressure.
The valve you have pictured is a pressure differential valve.
Rebuild seals are available from Muscle Car Research.com (see following link).
https://musclecarresearch.com/valve-kit-whead1
- 69f-100
Any idea how to get it out? It appears to be froze in there. I have it soaking in pb blaster right now.
Probably a big mistake. PB Blaster is a petroleum based product. It will make the seals swell, causing them to grip the differential valve spool even tighter.69f-100 wrote:Any idea how to get it out? It appears to be froze in there. I have it soaking in pb blaster right now.
Brake system seals aren't compatible with petroleum based products because brake fluid (DOT 3, 4 and 5.1) are synthetic based fluids --not petroleum based.
At the bottom of the link I provided, it gives a teardown/rebuild procedure on that valve. Listed in blue letters that says: ("Complete rebuild instructions.")
If you get the valve internals out, you need to make sure you get all the penetrant oil residue out/off of the valve, so that it doesn't contaminate the new seals and ruin them.
- 69f-100
I sprayed it all off with brake clean, just got to find something to soak it in.
- 69f-100
What do you recommend as a penetrant oil?ultraranger wrote:Probably a big mistake. PB Blaster is a petroleum based product. It will make the seals swell, causing them to grip the differential valve spool even tighter.69f-100 wrote:Any idea how to get it out? It appears to be froze in there. I have it soaking in pb blaster right now.
How about acetone and synthetic automatic transmission fluid? A while back somebody posted a very scientific experiment to determine the best rust busting compound between 6 different products and compounds like PB, WD40, Kroil, etc. A 50/50 mixture of acetone and ATF beat them all in something like a 2" bolt/but rusted together broke loose with 500# torque or something crazy high like that. Synthetic ATF is non petroleum based so may be compatible. Just a thought.
To remove piston, remove yellow plug on the end and apply air pressure to the port with the light blue plug. The other ports might have to be plugged with screw in plugs. If air doesn't do it, I made up a plug with a zerk and used my grease gun to push out the piston. You will have to get all of the grease out of the body and ports. That takes the most time. I also installed new o rings on the piston and wetted it with brake fluid before insertion into the main body. If you mark the waist with a Sharpie and peer through the center port you can have the piston centered before you install it. Get or make the "piston position hold screw" and insert into the switch port to hold position of the piston. Install the rebuilt valve and brake lines except the switch. Bleed brakes and road test. Finally, reinstall the switch. The brake light on dash should only light on startup but stay out during drive mode.
66 F250 camper special
69 F250 Explorer
85 Mustang GT with 1900 original miles
92 Festiva with 538,000 original miles
86 E350 extended WB van
Various IH & JD tractors (5)
TT & XT500 mc's (6)
BSA, Triumph's and twenty Yamaha two strokes
69 F250 Explorer
TT & XT500 mc's (6)
- Ranchero50
I had to clamp mine in the vice with the far end against something solid and drive the plug free with a brass punch. Need to be gentle and not bugger it up but also shock it hard enough for it to move. Once it broke the corrosion grip it came out pretty easily. Gave it a swipe with a Scotchbrite pad and it went back in smoothly.
100 psi of air has about 20 lbs of force on a piston that small. Shocking it with a 2lb hammer will generate 200 or so. I was never much good at math but understand the practical application well enough.
- 69f-100
I sure hope I can get it out, it's really stuck in there. I just can't get a pair of needle nose pliars in there to grab a hold of it. Not sure if I have a brass punch that small or not. I'm going to work on it again this weekend.
- 69f-100
I just cannot get this piston out of this valve. It is really stuck in there. I've got it soaking in acetone, hoping it will help.
There are numerous synthetic penetrant oils on the market. This is just one such example.
https://m.grainger.com/mobile/product/L ... tic-29FX97
- 69f-100
I'm going to have to try and find one, it just will not come out. I posted in the "parts wanted" section, hopefully someone has one.
