thanks for helping out in the past. Slowly working on/running for ice cream in a 1970 Ford F250 Camper Special. When i got it in January i did the front drums and a bunch of other stuff. At the time the e brake worked as well. Didn't touch the rear though as i thought the brake lines needed to be re run from the front. When my e brake went the other day i figured it was time to attack the back. Pulled axles and drums off and removed the diff cover and drained. Ordered new everything for brakes (drums, cylinders, springs etc) but will clean up the hubs with wire wheel and reuse them.
Couple of questions. Do i need to replace the gasket at the axle end? The metal is all there but it looks like there was some paper or something on the inside of the gasket up against the hub that is mostly gone.
is there a good walk through for servicing the brakes? There are several videos around that cover the front in detail but haven't seen anything for the rear at all. Am i on the right track?
Thanks, looking forward to going for ice cream again.
Lloyd
