Frame widths
Bunkerhillbilly
Frame widths
Post by Bunkerhillbilly »
Hey guys. I was wondering how much wider is the 73-79 frames than the 57 to 72 frames. What is the actual width of each. I could crawl under mine and measure em but it's a little chilly here in Illinois this time of year!!
Ohiotinkerer
Re: Frame widths
Post by Ohiotinkerer »
This should help you out........ :thup:
http://www.fordification.com/tech/chass ... arison.htm
This site has the best resources that I have found anywhere..... :fr:
1997 Honda CBR 900RR
Bunkerhillbilly
Re: Frame widths
Thanx that helps alot. Does anyone know if the 57 to 64 frame is the same frame Ford used for the 65 to 72??
cep62
Re: Frame widths
Post by cep62 »
No they are different.
What are you wanting to do ?
Bunkerhillbilly
Re: Frame widths
Something no one will understand. I got under my 64 and my 77 with a tape measure. They are the same width. I'm gonna rip out that bogus twin I Beam **** and put in a 57 straight axle. Once I get that big goofy cross member and all the rest out of it I should easily take 200 pounds off the front. I'll set up the steering with a cross steer set up and keep my power box. So basically I'm building a 77 step side gasser
Bunkerhillbilly
Re: Frame widths
Gunna get a 4" lowering kit for the back and shackle up the front for a nose bleed attitude
cep62
Re: Frame widths
Post by cep62 »
We'll need to see pictures of that. :eek:
Bunkerhillbilly
Re: Frame widths
Gimme till bout September! LMAO
