Today I started the truck up and heard a clunk, coming from the trans. I think im going to change the fluid to see if that helps at all. What kind of fluid do you guys use in your 3spd manuals? this is probably a newb question too, but how do you guys fill the thing up w/o spilling fluid everywere? also how much should I put in?
-Ethan
trans fluid
- boots
trans fluid
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- binder56jd
re: trans fluid
adding lucas gear oil stuff is good also- fill it till it is just below the fill hole- i use the qt gear oil bottle with clear plastic tubing-jd
now serving #235
now serving #235
re: trans fluid
Get one of those little pumps they sell at the parts store. Just get 90wt
or whatever they got thats close. It don't make much difference. Take
the fill plug out of the side and pump it in till it runs out. Have a can or
pan under to catch the overflow. You can save it and pour it back in the
bottle.![Smile :)](./images/smilies/icon_smile.gif)
bottle.
- boots
re: trans fluid
ok thanks alot guys ![Smile :)](./images/smilies/icon_smile.gif)
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- boots
re: trans fluid
today I drained the trans, and then added the new fluid. I almost cried when I saw how much fluid was in the trans, probably about a 20th of a quart. I felt so stupid that I didnt change it, or even CHECK it when I replaced the clutch. I still have a knock in the trans, not a u-joint or any of that stuff, I can feel its in the linkage, because when I put my foot on the pedal I can feel it clunking a little. When I press the pedal in it does not clunk at all, and shifts very smoothly. any suggestions on what I should check?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- pat67shorty
re: trans fluid
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
69 F100 300I6
91 Bronco 351
