In dash radio speaker
Does anyone have a recommendation for an am/fm radio speaker that fits in stock position under dash pad?
Re: In dash radio speaker
Mac's.
Part No. 64-12142
Works OK. Not unhappy with it. Not thrilled either. The metal bar thingy that holds in the factory speaker will be useless. I used very pointy 9/16" Phillips Lath screws as fastening hardware. Electric drill with a very long #2 bit. It was kind of a pain in the butt. But with patience and a flashlight between my teeth, I managed a sturdy install.
Part No. 64-12142
- jzjames
Used the one from Autozone, oval shaped like the original, but it was not a direct fit.
I tied it in place with zip ties, and it has sounded "pretty good" ever since.
If you look at some of the Mustang venders, you will find a dual speaker setup that fits into the original position.
C J Pony Parts has a 4x10 Custom Autosound Dash Speaker Dual Voice Coil 4X10 1965-1966 mustang how well will this fit in '66 dash
Thanx, Grit
Thanx, Grit
I have 1966 F100, that I am asking about the speaker. any help, Thanx
i want to do this as well later when i get the am 67 radio overhauled for fm. following......
- urchinhead
I ordered one from these guys, who were extremely knowledgeable:
http://www.turnswitch.com/
Works great. I tossed the 1980s Blaupunkt system
And went back to stock for my 1970.
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
